Audio help posted by Evan(CA) on April 23, 2008 at 01:18 AM
did this just recently happen? I had the same problem with a sub a while back, turned out the sub was blown cas it smelled like ass and turned of the amp whenever it hit hard. There could also be a fault somewhere in the wiring so double check that! Test the amp on another set of speakers if you can.
That red light is the warning/protect light , which means something is wrong.
